L Series owners
   / L Series owners #1
Hagalaz14w
Mexifornia
Kubota L3200
Seems most people here own a BX series Kubota.
Any L series owners here? I'm a first time tractor owner with a nearly new(13 hours when I bought it)L3200. Any advice or suggestions?
   / L Series owners #2
I have a 2002 L-2600 Bought new in 2001. Very dependable, no issues, never been to shop.
   / L Series owners #3
I have the 'brother' to your l3200, the l3800 and haven't found much work it can't handle. The jerky 3 pt system, it's only flaw, was tinkered with by a Kubota regional service rep and made the issue very manageable with a minor side effect being a slight drop in elevation of a 3 pt implement when the front loader valve is max'd out on a bucket curl. Not a big deal to me as I don't typically use the 3 pt and loader concurrently.
An extremely reliable and rugged tractor. I'm confident you will be pleased with your purchase.
   / L Series owners #4
Lots of L owners here including my L4300. A real workhorse that's priced a little better and with fewer electronics to cause problems. Works for me.
Some are a little light in the front and benefit from added weights. I found that New Holland skid steer weights fit perfectly and are cheaper since I can buy used or imports. It's only weight, after all. My weight bracket and grille are home made and the first photo is maybe 8 or so years ago when it was newer.
   / L Series owners #5
Former L3400hst owner here. I would be willing to bet there are thousands if not 10's of thousands of L series Kubota, members.
   / L Series owners #6
I'm new here also with a new L4701.
   / L Series owners #7
L4600 here.
You have an excellent machine without the emissions stuff, you are gonna love it.
   / L Series owners #8
Some are a little light in the front and benefit from added weights. I found that New Holland skid steer weights fit perfectly and are cheper since I can buy used or imports. It's only weight, after all. My weight bracket and grille are home made and the first photo is maybe 8 or so years ago when it was newer.
My dad has an L3000 that looks very similar to that body style.
He also just recently bought an L4600HST
   / L Series owners #9
Bought new L2800 in 08 here, im always amazed at what it has done and what it can do. Built like a rock, never failed to do what I need. ONLY prob I had was that rubber tube by your right foot cracked and made the hydraulics act up until I got a new hose. Other than that its been perfect. I wouldnt hesitate to but a L series again.
   / L Series owners #10
Tons of L owners here. I'm on my second. They are not quite as common as the B's but that is just the nature of the sweet spot of the CUT market. That B size covers most homeowner/hobby farm types quite well so there are a lot more out there. When you get a bit bigger property or other needs (in my case - logging work on my land) then you get into L's...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2013 RAM 5500 (INOPERABLE) (A50854)
2013 RAM 5500...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2015 MACK GU713 (A50854)
2015 MACK GU713...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
