3-Point Hitch L-series Jerky 3PH - Jeff's homebrew repair.
   / L-series Jerky 3PH - Jeff's homebrew repair. #201
Come back and let us know what you end up getting. You have to post pictures as well.
   / L-series Jerky 3PH - Jeff's homebrew repair. #202
Now life goes on, Kioti??
So you are going to go from a tractor that had a jerky hitch to one that has a hydro pedal that sticks?
   / L-series Jerky 3PH - Jeff's homebrew repair. #203
Is Kioti having problems with sticking hydro pedals? Interesting first I heard of it. My NH TC40D used to stick if the RPMs were set too low.
   / L-series Jerky 3PH - Jeff's homebrew repair. #206
I guess I'm asking you.
The CK25, CK27, CK30, and CK35 are all candidates for the sticking hydro pedal. I had this problem on my Bobcat CT235 which is the same as the CK35.
   / L-series Jerky 3PH - Jeff's homebrew repair. #207
Has Kioti come up with a fix, or is this ongoing? Or are they saying there isn't a problem?
   / L-series Jerky 3PH - Jeff's homebrew repair. #208
In my dealings with Bobcat they replaced the hyrdo return spring multiple times. Adjusted the pedal. Cleaned the neutral valves and replaced teh neutral valves. Then when all of that did not fix it they wanted to do a hydro. The hydro they wanted replace it with was the same as the one in the tractor, not updated. I have never heard what is wrong internally with the hydro to cause this.
KiotiKen had similar problems with his and Kioti replaced the hydro off the bat.
I listed several threads on the sticking hydro pedal on post 21 of this thread.
http://www.tractorbynet.com/forums/buying-pricing-comparisons/297377-yanmar-ex3200-kioti-ck30hst-3.html
   / L-series Jerky 3PH - Jeff's homebrew repair. #209
LOL There is no perfect tractor out there! :D
Well, maybe a Grand L...
   / L-series Jerky 3PH - Jeff's homebrew repair. #210
I'd go for the shuttle, don't like the HST.
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
2019 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2019 Peterbilt 389...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
