5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,785
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
I thought I would post an update on the air conditioning situation on the L series cab model Kubota's:
I returned the questionnaire that Kubota sent me, detailing my modifications to the cooling system as well as the added shrouding in front of the radiator.
I also made my dealer aware of what i had done.
Last week, I received a call from Kubota Tractor in Torrance California. I spent some time on the telephone with a design engineer, explaining what effect my modifications caused in improving the air conditioners ability to cool the cab.
The engineer told me that Kubota was experiencing trouble with the a.c. unit's ability to keep the cabin cool in hot weather conditions.
The engineer also told me that Kubota was moving the oil cooler farther toward the grille in an attempt to allow more cool air to flow through the a.c. evaporator or condenser or whatever.
The engineering department was very impressed with my modifications as well as the ball type shutoff valve in the hot water feed line.
As of that time, the American Engineering department was going to contact the parent factory in Japan to discuss my modifications and consider a similar factory modification or retrofit to eliminate the air conditioner problem.
I might add that in light of Kubota's stance on non-factory modifications voiding the Kubota warranty, the factory engineers felt that my modofication would, in no way jepordize my warranty. It is my understanding that modifications not authorized by Kubota Tractor Corporation may indeed, void the factory warranty.
