L-39 Wheel weights actually fit nice!
/ L-39 Wheel weights actually fit nice! #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Another 530 lbs total brings weight up to 7,800 lbs with bucket, and 8000Lbs with grapple, not counting operator.
The BH-1000 is still strong enough to lift all 4 wheels off ground and the stabilizers still lift the machine.
The L-39 looks so much more stable at only 1.75" wider. Chains will fit nice, if I chose to add them. Mud season will tell.
I bet it will push into a pile better. These machine should weigh at least 4 tons.
16mm-1.5 x 80 mm STUDS are Kubota PN# 01517-61660 A-572.
I could add another 300 Lbs or so wiht weights that bolt on the outside of the rim, but as is may be the ideal power to weight for the L-39
  • l39_Wheel_Wt#1.pdf
  • L-39_w_wheel_80MM_Studs#1_2-25-07.pdf
  • L-39_w_wheel_weights_front#1_2-25-07.pdf
  • L-39_w_wheel_weights_rear#1_2-25-07.pdf
  • L-39_w_wheel_weights_side#1_2-25-07.pdf
  • L-39_w_wheel_weights_side#2_2-25-07.pdf
  • L-39_w_wheel_weights_tire_spacing#1_2-25-07.pdf
  • L-39_wheel_weights_right_side#1_2-25-07.pdf
  • L-39_wheel_weights_right_side#2_2-25-07.pdf
  • L-39_wheel_wts#1_2-25-07.pdf
  • L39-TL1000_Loader_Tube_Weights_Test_Fit.pdf
Attached for use by anyone if they choose are my final drawings of a 800 LBS weights for rear the wheels to an L-39's 40x15-19 Rears.
I do not have the outside weights on yet, as I just gave the prints to the shop.
The weights are flame cut from 4.5" thick plate drops. Often you can get a better price on a drop than buying from a new plate.
The weights use a longer 16mm-1.5 x 80 mm STUDS, Kubota PN# 01517-61660 A-572, and increase track in rear by 1.62"
I have loaded my Kubota to 800 lbs total so far and can report increase in the tractors ability to push into a pile. Another 300 pounds of outside weights that I will add will push machine weight with bucket to 8,100 lbs and 8,300 Lbs with my Borgford grapple. Add another =200 lbs. for the operator and the little 3 cylinder has to move 8,500 lbs. The weight can only really be felt going up hill.
  • L-39_Wheel_Wt#Inside1.pdf
  • L-39_Wheel_Wt_185lbs_Outside.pdf
Finally got my outer wheel weights manufactured and installed.
Now at 8,100 lbs plus, the L-39 can actually do some work! A lot safer also.
The forks will come in real handy, in fact they already have.
  • L-39-Forks#3.pdf
  • L-39_Outer_wts#2.pdf
  • L-39_Outer_wts#1.pdf
  • L-39-Forks#2.pdf
John Deere 5525 (A60462)
John Deere 5525...
2004 Case JX75 (A64126)
2004 Case JX75...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
2016 John Deere 6155R (A64119)
2016 John Deere...
Tennant M30 (A64127)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
