L 3200 fuel filter housing breakage
   / L 3200 fuel filter housing breakage #1
lonegunman
Eastern Washington
Kubota L-3200
Yesterday, I was out in the woods dragging a few logs and clearing a trail with the box scraper and a random chunk of 2" broken pine branch kicked up by the front tire stabbed into the clear plastic bowl for my fuel filter. It promptly stabbed thru the cheap plastic and ended my workday. It ended it in the woods, 40 miles from home and 45 minutes from the nearest parts store. NAPA had a metal fuel filter with and "in", "out" and a 1/4" return line so we bought it and drove back into the woods to find my tractor.
I have always looked at the poorly located and cheaply made fuel filter and wondered if it would be a problem, the answer is a yes. It took a while to prime and start the tractor. Opening the air valve and turning the engine worked after 30 or 40 tries and she fired up. After a few minutes of sputtering while the air worked thru the injectors everything was back to normal.
Today, I ordered a part I never knew I needed from a company I never heard of and I'm hoping it works. http://coupersproducts.com/kubota-l3200-l3800-fuel-filter-protector/
A powder coated metal cage for the filter and bowl. Apparently, it happens more often than you think.
O'Reilly's auto parts has a "special price" for their fuel filters. The $14 dollar filter for my tractor was $43.00 bucks because it was Sunday and I was in a pickle. I declined and headed for the NAPA five miles farther down the road. At NAPA, I said nothing and it was,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,$14 dollars.
   / L 3200 fuel filter housing breakage #2
Judging by the fact that "Mr. Couper" took the time to design and market the fuel bowl protector, it has happened more than once!
   / L 3200 fuel filter housing breakage #3
i went through 4 filter assemblies on my L3200. the oil filter got stabbed a couple times as well. they need to protect these components better when they design a unit.
   / L 3200 fuel filter housing breakage #4
I had less than 10 hours on mine when a stick took out the fuel filter. I carefully drove mine out of the woods and back to the barn while the fuel level got below half full so I could change it without the fuel flowing during the change over. I then had to drive 33 miles one way to get more filters and bowls. Since I now have extras, it has never happened again.
   / L 3200 fuel filter housing breakage #5
They make equipment designed for the woods...
   / L 3200 fuel filter housing breakage #6
I'm glad they moved the separator on the L3901, I use my tractor a lot to cut fire wood and am in the woods all the time. It being up front like that has to make it easier to hit it with something. The picture I looked at it looks like it sticks out past the plastic cover.
   / L 3200 fuel filter housing breakage #7
...A powder coated metal cage for the filter and bowl...
Looks cheap and doesn't look like it would protect anything....
Let us know how it works out for you...
Long Long ago, someone on TBN made a protective shield for the filter.... (too bad the search feature stinks on TBN....)
   / L 3200 fuel filter housing breakage #8
That was Gomer who made a fuel filter guard for his B series tractor-SW Michigan if I recall.
Try a search!
   / L 3200 fuel filter housing breakage #9
Try a search!
Here you go.. took me about 15 seconds to find that one..
http://www.tractorbynet.com/forums/...0-b3030-fuel-filter-guard.html?highlight=fuel
   / L 3200 fuel filter housing breakage #10
I shamelessly copied Gomer's design for my B7800, after having a broken filter housing incident. Pretty simple to fabricate. Mine has a square corner and I made it so I had enough finger room to service the filter. I haven't tested it yet, and I don't plan to, but things happen.
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2008 D&P WELDING 18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
2014 Ford Escape (A50324)
2014 Ford Escape...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
