L 2900??
   / L 2900?? #1
daTeacha
Veteran Member
Funk, Ohio
I've been lurking around here for a bit, with an auction coming up near me. I went to see the Kubota L 2900 they had advertised. I've decided against it, but that is not the reason for this post.
Prior to going to see it, I've been haunting the web looking for something, anything, about an L 2900 and found nothing. The thing is HUGE compared to my B7100. It had rear tires about 12 inches wide (R4) on 24 inch rims. The loader was 5 feet wide, the ROPS was about 7 1/2 feet above ground level. He said it had 29 HP, and it had the GS transmission.
He pulls a 7 foot box blade with it, among other things, which impressed me for a 29 hp tractor.
I was expecting something a bit larger than the B 3030 or at least not much bigger than some Ls I had seen at the dealerships. The seller figured that with the loader and the 3 weights (50 - 75 lb per weight)) on each rear wheel that it weighed in around 3000 lb. My tractor comes in at around 1300, if that.
Is this a rare model or something? I still haven't found anything on the web about it.
   / L 2900?? #2
According to Kubota.com "prior products", it appears that it was introduced in 1994 as part of the Grand L series.
   / L 2900?? #3
I bought a Grand L2900 GST 4WD new in Oct. 1996. Got 130 hrs now with NO Problems. It was the smallest of the Grand L Series(L2900/L3300/L3600/& L4200) which premiered in 1994. The L2900 has 32 gross HP/29.7 Net HP, 12.4-24 R. tires & a base weight w/ROPS of 2810#. GREAT Tractor!!!
   / L 2900?? #4
dataecha
As has been mentioned, the L2900 was a prior model of the current L3130 tractor. Production started in 1994, then it became the L3010 and finally the L3130.
Lewis
   / L 2900?? #5
I had a L2900 GST for 7 years and never had a problem with it. A very good tractor and very cheap to run, cheaper then my new 3430.
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2004 Delta Spread-Axle Gooseneck Trailer. 20ft+5ft. (A56438)
2004 Delta...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
