L-235 hydralic oil filter
/ L-235 hydralic oil filter #1
snakeeater
Canton,TX
L235 Kubota
in Dec, I changed the hydralic oil filter on my Kubota because the FEL and 3pt stopped working..it fixed the problem..now it's doing the same thing...what do I do..change the fluid and the filter or just the filter again..is there an alternate filter I can use rather than the expensive kubota brand..there must be some trash in the system for it to clog the filter so fast..the manual says you can clean the filter,,but I don't see how..help... /forums/images/graemlins/frown.gif
/ L-235 hydralic oil filter #2
I think I would change the filter, but you might drain the fluid, let it settle and see if there is anything (large enough to spot), in the bottom of your drain bucket(s). Is the hydraulic fluid getting cloudy or discolored? If everything looks ok, put it back in.
I don’t think you can clean a hydraulic filter. You should not be looking for a cheap filter, you need the best filtering you can put on that pump, and you might get lucky and remove what ever is in your system.
Have you shared any cylinders with anyone? Your containments can only come from outside the system OR inside, something wearing out or breaking down. Good luck hope you get to the source of the problem. KennyV.
/ L-235 hydralic oil filter #3
Be grateful the filter is clogging, that means it is catching whatever is contaminating the oil.
I would change the oil and filter and maybe strain the old oil through a coffee filter before disposing of it to see what is in it. Also, run a magnet through the old oil and see if you pick up any metal shavings.
Bill Tolle
Thanks for your reply..I really appreciate it..I rebuilt the cylinders last year and did not change the fluid at that time..maybe some contaminates got in..I will change the oil and filter..
Thanks for your reply..I will take your advice and I agree with you for sure..hope all is well in Jasper..y'all come see us up here in First Monday Canton..
2007 MACK CXP613 (INOPERABLE) (A63569)
2007 MACK CXP613...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A63569)
2017 FORD F-150...
