L 130 Kohler 23 HP surging
   / L 130 Kohler 23 HP surging #1
sredford
midlothian, virginia
2005 John Deere L130
Engine surges unless choke is almost fully on. Seems to run a little better under load..maybe. Changed fuel filter and pulled carb bowl and cleaned it. Jet from bowl to carb is clear. Any suggestions?
   / L 130 Kohler 23 HP surging #2
Twiddle the high speed jet and then set it about 1/4 turn out or so and see if things change? (DON"T loose track of where it's set now!)
If so, "exercise" the needle, there may be some "varnish" that needs to be jostled and cleared.
Happens on the Bolens from time to time (23 hp K series Kohler) I have not had to remove the carb yet ;-)
High speed jet is closest to the engine.
   / L 130 Kohler 23 HP surging #3
I use SeaFoam in my fuel for the first run of the season and it solves a lot of problems I had with my L130.
   / L 130 Kohler 23 HP surging #4
I had a similar problem. Took the carb off three times to clean it before I got it clean enough. When cleaning, run small wires through the jets and openings followed by carb cleaner and, then, air. Mine has been fine now for two years after I got it cleaned right.
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Rear Tine Garden Tiller (A51573)
Rear Tine Garden...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
