Ky basketball
/ Ky basketball #1
Ky basketball
Ashland Kentucky
Kubota 1860
My Agri-cutter Model 203 serial number 001042 shears bolts off faster than I CAN REPLACE THEM.
It has a small oil leak but there is plenty of lubrication in the gear box.
My small rough cutter does not have a clutch in line, is this the problem?
/ Ky basketball #2
Be sure to not start the cutter while under load. Engage the pto slowley. Go down a gear. Raise your cutting height. Some times you can go up one grade bolt and be ok. A clutch would be best of all worlds. Ken Sweet
/ Ky basketball #3
Also, do you have debris in the field that you're hitting?
Ken
/ Ky basketball
I don’t know what happened to the cutter. I bought it used and it worked fine for the first year. The next year it had an oil leak and I tighten down the bolts thinking that it was just a leaky gasket.
Then the bolt sheared. Got a new bolt same grade at Tractor supply and it sheared it also. After that I started buying bolts by the handful I would get a few passes mowed and then I had to bring it in and put in a new bolt then go back to work. I did not change the height or any thing from the first year. The plastic safety guard had melted and I cut it off. I am through this year and will not be using it until spring I would like to fix it this winter.
Thanks for the greetings from everyone it made me feel at home.
/ Ky basketball #7
Since it only started after you tightened the bolts, is it possible you have the gears setup too tight that causes running hot and in a bind?
/ Ky basketball #9
How did the plastic shield melt off? Was this caused by excessive gear box heat? If so then it sounds like you might have some major gear box problems.
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2021 Caterpillar 4-in-1 Bucket (A64126)
2021 Caterpillar...
Forklift Boom (A62679)
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
