Problems on my Kubota kx121-3 mini excavator are: Blade drifts down constantly making it useless for grading. Also, when the left travel lever is moved forward, the blade raises to full height. I've recently purchased 2 new check valves to put into the blade section of the hydraulic control valve stack but have not installed them yet. I'm thinking that the rotator joint seals are worn out and are allowing hydraulic oil to bypass them and migrate to places it's not supposed to inside the rotator joint. I believe the hydraulic fluid that is supposed to be going to the left drive motor ends up going to the upside of the dozer blade. Does anyone have experience or advice for these problems. Should I pull the joint out and reseal it? Am I wrong in what I think it might be?
I'm a new owner to this 2004, 5000 hour machine and am not a mechanic or experienced operator but am not afraid to dig in and fix things.
