KX121-3 Not moving. Lock
   / KX121-3 Not moving. Lock #1
KX121
Saratoga Springs
kx121-3
I'm a new Kx121-3 owner and I got it locked up on a jobsite. I pulled the lever up on the left as always to get out of the cab and my shirt caught the lock lever and pulled it down hard. Engine runs, turns on/off fine, etc. The lock lever is only recognized as being in the locked (UP) position no matter if it's up or down. Any
   / KX121-3 Not moving. Lock #2
You bent the lever. Pull the screws out of the plastic arm rest. Look aroud you will see the safty switch and the metal tab that needs to hit it. I own 8 kubota excavators and thats a common prob
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
