KX 057 Combine Aux Flows?
   / KX 057 Combine Aux Flows? #1
lumberjack1986
Columbus, MS
Gehl AL340
My 057 has the dual aux option, ~10 and ~20gpm. My question is can those flows be combined for a theoretical ~30gpm?
I realize I could turn the pressure up on the second aux and approximate the same hp, but one stump grinder I'm looking at has a flow range of 25-40gpm which means I could use it on the ex and CTL.
A simple y connector on the pressure line would handle combining the flow (one way). In my testing dead heading the circuits, both add load to the engine individually and combined. I realize I'll likely need to add cooling capacity. Why won't it work?
2012 Peterbilt 388 Sleeper Truck Tractor (A53117)
2012 Peterbilt 388...
2015 FORD F550 UTILTY TRUCK (A51406)
2015 FORD F550...
2013 DRAGON ROLL OFF TRAILER (A53843)
2013 DRAGON ROLL...
150' 1-1/2" 325PSI Hose (A52384)
150' 1-1/2" 325PSI...
2005 Wabash National 28ft Dry Van Trailer (A51692)
2005 Wabash...
