Tiller Kuhn L32 rototiller-need help plz
   / Kuhn L32 rototiller-need help plz #1
jmdrewme
Kubota B7800
Hello all! This is my first post but I have gotten alot of questions answered just by reading. Anyway, I put my tiller on my B7800 Kubota tractor today to do the fall tilling. I tilled my neighbors garden with no problem. When I started tilling mine, it worked fine at first. Then it got loud and now it won't till into the ground. The blades turn fine until I drop it to the ground to work. I checked the chain case and can't see any oil. My question is what kind of oil do I put into it? Should I check the gearbox if I can get it to open? Thank you in advance.
   / Kuhn L32 rototiller-need help plz #2
Assuming you do not have a limited slip PTO shaft clutch-
I would most certainly say that you have a broken shear pin which explains why it runs when its out of the ground.
The gear oil you need is at least a 90 wieght gear oil.
Thanks!! I'll check it out in the am.
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53485)
THIS WILL BE A...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
