Tiller Kuhn L32 rototiller-need help plz
   / Kuhn L32 rototiller-need help plz #1
jmdrewme
Kubota B7800
Hello all! This is my first post but I have gotten alot of questions answered just by reading. Anyway, I put my tiller on my B7800 Kubota tractor today to do the fall tilling. I tilled my neighbors garden with no problem. When I started tilling mine, it worked fine at first. Then it got loud and now it won't till into the ground. The blades turn fine until I drop it to the ground to work. I checked the chain case and can't see any oil. My question is what kind of oil do I put into it? Should I check the gearbox if I can get it to open? Thank you in advance.
   / Kuhn L32 rototiller-need help plz #2
Assuming you do not have a limited slip PTO shaft clutch-
I would most certainly say that you have a broken shear pin which explains why it runs when its out of the ground.
The gear oil you need is at least a 90 wieght gear oil.
Thanks!! I'll check it out in the am.
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
