Kuhn EL53 Slip Clutch problem, any suggestions?
   / Kuhn EL53 Slip Clutch problem, any suggestions? #1
Snowflakes
Hyde Park, Vermont
Kubota MX5200 with backhoe
HI,
At the end of last year we bought a new Kuhn EL53 rototiller because our old rototiller was too narrow and would not cover the width of the tractor tires. This spring I was all excited to use our new rototiller.
I followed the directions in the manual precisely as it was the first time I used it. After about 30 feet of rototilling the slip clutch started smoking like mad. There was nothing in the ground like a big rock or root so I read some more and talked to the dealer some more too.
As a result of that, I loosened up the bolts holding the slip clutch together so they would slip easily and put the rototiller in the soil and ran it for a couple of minutes. Then I tightened up the slip clutch bolts to the factory specs in the manual.
I put the rototiller in the dirt and this time got to 42 feet before it started smoking like mad. I made a little progress 😊 . Unfortunately our beds are between 100 and 300 feet long so I cannot make it through even one of the short beds.
I have never had this experience with slip clutches before. I could just tighten up the bolts all the way and it would never slip. The only problem with that is when I hit a big rock or root, it will damage the rototiller.
Does anyone have any experience with the Kuhn slip clutch? Have you been able to make it work?
Does anyone have any suggestions other than take the rototiller back to the dealer and return it? Commiserations welcome 😊 .
Regards and thank you,
..michael..
   / Kuhn EL53 Slip Clutch problem, any suggestions? #2
Usually the first use of a new tiller, the story goes the other direction and we hear about the clutch not slipping and killing the tractor.
How much horse power does your tractor have? Maybe you have too much tractor.
The tractor is a Kubota MX5200 (52hp).
   / Kuhn EL53 Slip Clutch problem, any suggestions? #4
I think I would keep tightening the bolts a little bit at a time till I could make the pass without slipping.
   / Kuhn EL53 Slip Clutch problem, any suggestions? #5
I think so also.
   / Kuhn EL53 Slip Clutch problem, any suggestions? #6
HI,
..michael..
Always disc ground first to loosen the soil. I'm 51 and we still use the same LONG brand tiller we had when I was a kid. Now, I've seen guys that didn't loosen the soil first. They had gotten used to fixing tillers pretty good. But, ours has not been worked on.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2014 Nissan Pathfinder SUV (A55853)
2014 Nissan...
2023 TRANSCRAFT 53FT FLATBED TRAILER (A57880)
2023 TRANSCRAFT...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55315)
2017 Rogator...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
