Mowing Kubuto ZD28 Loss of Power
   / Kubuto ZD28 Loss of Power #1
freycorm
Kubota ZD 28
I own a 2004 Kubota ZD 28 (diesel with 72" deck) zero turn mower. Mower runs fine at first, but as it heats up, loss of power is experienced. When it happens, it smells like it is running rich (diesel smell). We have changed filters, cleaned (and changed) fuel lines, dropped and cleaned fuel tank, etc. We have also checked all valves and compression and all are fine. We have also watched the fuel filters when we experience the loss of power, and the filters have normal fuel levels running through them. Mechanics that have done this work for us are at a loss.....can't figure out what else it could be. Any suggestions?
we changed the air filter, and no restrictions observed on the intake
Ok - thanks for the response. It only has the loss of power after mowing for a period of time.....basically after engine is hot. I can mow for 45 minutes or so and it runs perfect, then all of the sudden it starts running bad and loss of power. Does it every time.
   / Kubuto ZD28 Loss of Power #6
Well that indicates something else that is heat related. Something opening up from expansion.
   / Kubuto ZD28 Loss of Power #7
How about the muffler? Anything loose in it? Also could be a sticking injector when it get hot. I run some injector cleaner in my ZD21 about every 3rd tank( run red dye diesel)
   / Kubuto ZD28 Loss of Power #9
Sounds a bit like vapor locking... Does your fuel line lay close to the engine block, or near the exhaust?
Another thought, maybe some trash is floating around in your fuel tank and finally gets sucked down close to the outlet, causing somewhat of a fuel starvation or restriction.
   / Kubuto ZD28 Loss of Power #10
How many hours on the machine?
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
2003 Big Tex 10PI...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
