Kububota SVL90-2 undercarriage roller replacement
   / Kububota SVL90-2 undercarriage roller replacement #1
Tact
Eads, TN
I would imagine the procedure would be similar on other makes and models, but my rear roller bearing is shot on the right side. I have a replacement roller and was wondering if anyone has replaced this in the field without taking the track off? If I remove the grease fitting where you adjust the track tension and somehow get the tension loosened on the track, will there be enough slack in the track where I can simply unbolt the roller and drop it down under the track for removal? I hate the thought of having to remove the track all together as I will be doing this by myself or with a helper. These tracks are heavy to manhandle.
I've looked for videos, but the only ones I found were for track removal and replacements. Nothing for roller replacements.
   / Kububota SVL90-2 undercarriage roller replacement #2
I’ve never done it but l would think you should be able to change a roller without removing the track. Seems l remember watching a video of a guy changing the drive motor without removing the tracks. If you can get enough slack in the track & high enough off the ground it should be doable. I saw to push the track tensioner back to loosen track, place a 4x4 between bucket & track the curl bucket back to push the tensioner in.
I致e never done it but l would think you should be able to change a roller without removing the track. Seems l remember watching a video of a guy changing the drive motor without removing the tracks. If you can get enough slack in the track & high enough off the ground it should be doable. I saw to push the track tensioner back to loosen track, place a 4x4 between bucket & track the curl bucket back to push the tensioner in.
Thanks for the reply. Someone else mentioned what you suggested. I think I'll try that.
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
