Tire Selection Kubots B9200 Tires and Rims
   / Kubots B9200 Tires and Rims #1
WadeNolan
Derry Pa
Kubota B9200
I just bought a Kubota B9200 and it has Lawn tires on it. They are really wide. I'm looking to switch to all Ag tires. Can I use the same rims? Plus can I buy the tires from someone other than a Kubota dealer? Who sells them?
   / Kubots B9200 Tires and Rims #2
What size tires do you have? Is your tractor 2WD or 4WD?
   / Kubots B9200 Tires and Rims #3
Usually the rims are not the same.
My tires are Rear- 13.6 -16, Front 24X9 50-12 It is a 4 wheel drive. Want to switch to AG tires. Can I use the same rims?
   / Kubots B9200 Tires and Rims #6
You can use 12,4-16 AG tire on back, 7-12 Ag on front, they will fit your rims & work with your 4WD.
Ed
Ed
Is that the largest AG tire that my tractor will take. I want the largest and most aggressive tire the tractor takes.
   / Kubots B9200 Tires and Rims #8
That is the largest without changing rims. How tall of a tire can you go without hitting the fender or mower deck?
Thank You
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2005 International 4300 Heil S/A Dump Truck (A50323)
2005 International...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
WB Mower (A50121)
WB Mower (A50121)
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
