Tire Selection Kubots B9200 Tires and Rims
   / Kubots B9200 Tires and Rims #1
WadeNolan
Derry Pa
Kubota B9200
I just bought a Kubota B9200 and it has Lawn tires on it. They are really wide. I'm looking to switch to all Ag tires. Can I use the same rims? Plus can I buy the tires from someone other than a Kubota dealer? Who sells them?
   / Kubots B9200 Tires and Rims #2
What size tires do you have? Is your tractor 2WD or 4WD?
   / Kubots B9200 Tires and Rims #3
Usually the rims are not the same.
My tires are Rear- 13.6 -16, Front 24X9 50-12 It is a 4 wheel drive. Want to switch to AG tires. Can I use the same rims?
   / Kubots B9200 Tires and Rims #6
You can use 12,4-16 AG tire on back, 7-12 Ag on front, they will fit your rims & work with your 4WD.
Ed
Ed
Is that the largest AG tire that my tractor will take. I want the largest and most aggressive tire the tractor takes.
   / Kubots B9200 Tires and Rims #8
That is the largest without changing rims. How tall of a tire can you go without hitting the fender or mower deck?
Thank You
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
Frontier Forks (A50515)
Frontier Forks...
UNUSED CFG INDUSTRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
Case IH 900 6 R Planter (A50515)
Case IH 900 6 R...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
