Kubotoa L3800 FEL bucket volume?
   / Kubotoa L3800 FEL bucket volume? #1
bhh
Ulster County, NY
Kubota L3800
I can't seem to find this info anywhere! Does anyone know what the volume of a Kubtoa L3800 SSQA bucket is?
I need to move a specific amount of gravel and think calculating it by number of loads is going to be the easiest.
Thanks.
   / Kubotoa L3800 FEL bucket volume? #2
I can tell you that the 60" pin on bucket on my L3200 holds 1/4 yard per scoop when I get a good heaped scoop (which doesn't always happen unless the pile is big and easy to push into). That would be the same 60" pin on bucket the L3800 gets.
I think the optional SSQA bucket is 66", so it would hold marginally more (as long as it's not a light materials bucket, in which case you're not supposed to load it all the way up for heavy stuff).
Thank you. I hear you on the full scoops but its pretty easy with a load of item 4 gravel. A 1/4 yard is 6.75 cubic feet so 10% more than that (66" over 60") would be just shy of 7.5 cubic feet. Sounds about right I guess. I'll use that to estimate the amount of gravel I'm placing in each location. Thank you!
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
377811 (A48836)
377811 (A48836)
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
