Kubota's diabolical plot.
   / Kubota's diabolical plot.
OK, admitting I haven't done this type of clip...
How about just putting it around the main shaft to start (the thinner part in the rear of the pic)? Then once you have it around the shaft, spread it open and slide it into place over the tie rod end and boot. Looking at the pic, that's what I would try. It might take a mod to a pair of external snap ring pliers to make it work easily. Possibly hose clamp pliers would do it too. Or maybe just some duct tape protection on the finger tips...
If you ever have the opportunity, please try all your suggestions.
Then call me from the insane asylum.
   / Kubota's diabolical plot. #13
That bad, eh? :laughing: I really hate snap rings. Even with all types of different snap ring pliers they go on FAR easier than they come off. Especially the internal ones. I fought for an hour getting one out of a deep well on a tiller rebuild I did for a friend. Grrrrrr. I know from where you are coming...:cool:
It would be OK if it was a regular snap ring. Have a look at the photo - its just a double loop of super hard, springgy wire with nothing to grab on to. To top it off it has a full coating of grease just to further torment you.
   / Kubota's diabolical plot. #15
You should use a black cable tie. The white ones are not UV resistant and will get brittle and fail after a while if exposed to sunlight.
Good idea. It was all I had at the time but I'll swap it out for a UV resistant one later.
   / Kubota's diabolical plot. #18
I thought i was the only one going nuts trying to install this, I tried both greased and the cleaned everything off and tried again, thinking i can fill it with a grease gun needle when finished. Still had no luck. Desided that if i did get it on the boot would have a hole in it or the snap ring would be too bent out of shape to stay on. --funny I did the tie-rap about 2 yrs ago an did use a black one, still working. I only used black because I din't want anyone to notice that i could not get the correct snap ring on-- ring is more like a ring to hold your car keys together not a true snap ring. ---lots of credit to those that were able to install the correct ring. ---:)
   / Kubota's diabolical plot. #19
I did mine awhile back but I remember using two separate pieces of 24gage wire looped and slide it around the ring, then hold each piece used it to slightly pull the ring open once I got it started your able to slide the wire around on the ring and guide it into position at the same time. Then just keep on going round until it comes of the end on the ring. I hope that makes sense.
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
