Traction kubota
/ kubota #2
Can't think of the number but I have a 60inch front mounted plow that has hydraulic swivel. With this you need the subframe in order raise and lower the blade. I can switch between the blower and the plow in a couple of minutes. The rig uses the FEL control valve. All in all it is a sweet set up for my gravel drive!
/ kubota #3
Welcome to the forum. Is this a traction question or 3pt hitch lift issue? Snow plow? A little more info to what you're after would help. B series have different front end loaders(FEL) lift cap , quick disconnect or not , etc. Lots of help avail on this forum.
Cedar Boards (A65640)
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
