Kubota ZD326P VS ZD326S
   / Kubota ZD326P VS ZD326S #1
mchildress
Sealy,Tx
Received this responce from Customer Satisfaction@Kubota.com
Dear Sir:
The differences you mentioned below are the only ones between the two
models. The engines are the same and the transmissions are the same.
However, the gear ratio is reduced on the ZD326S to match that of the
ZD321, that is the reason for travel speed being lower. There are no other
differences. Thank you for your interest in Kubota!
Your Original Inquiry:
I am wanting to know the spec. differences in the ZD 326S and ZD 326P. I
have found the 326S does not have the run flat front tires and the speed is
0-9.4 vs the 326P speed of 0-10.6. Is there transmission difference for
they both have the same engine (D1005)or any other spec. differences?
Thanks
   / Kubota ZD326P VS ZD326S #2
The transmissions are geared differently. The ZD326S has a forward max speed of 9.3mph and reverse max speed of 5.2. The ZD326P forward speed max of 10.6 and reverse max speed of 5.3. Each has a different diesel engine. The ZD326S uses a D782 3 cylinder rated at 26 gross HP at 3200 rpm. The ZD326P uses a D1005 3 cylinder rated at 26 gross HP at 3200 rpm. Both have a total displacement of 61.08 cubic inches. That is the only differences I know of.
2013 Infiniti M37 (A50324)
2013 Infiniti M37...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2019 Western Star SF4700 Dump Truck (A47384)
2019 Western Star...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
