Kubota ZD28 Losing Power
   / Kubota ZD28 Losing Power #1
Glowplug
3rd Planet from the Sun
Kubota M7040HD
I have a Kubota ZD28F zero turn mower with 700 hours. I believe it is a 2005. Just recently it started losing power after a period of use. Basically it will run fine then after some time, maybe a half hour or so, it will start to periodically lose power, almost to the point of cutting out. If I just sit there and turn the blades off after a moment it will regain power and run fine until it does it again. It seems to likely be a problem with the fuel delivery. I am going to get a new fuel filter as the next step. The thing that is so strange and interesting though is that it doesn't do it until after it has been running a bit. I found this thread the other day and this is exactly the same problem I am having. Unfortunately the thread has no final resolution. Any thoughts and help would be appreciated.
   / Kubota ZD28 Losing Power #2
You might want to double check but I believe that there is a hard to find filter that often gets missed near the frame other then the obvious one!
   / Kubota ZD28 Losing Power #3
I had to replace my 2 filters on my zd326 because it was doing what you described.
   / Kubota ZD28 Losing Power #4
I have to replace both filters and blow out the line every year. Always solves it. I also had to replace the electric fuel pump a couple years ago.
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
CAT Skid Steer (A50322)
CAT Skid Steer...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
