Kubota ZD28 Losing Power
   / Kubota ZD28 Losing Power #1
Glowplug
Veteran Member
3rd Planet from the Sun
Kubota M7040HD
I have a Kubota ZD28F zero turn mower with 700 hours. I believe it is a 2005. Just recently it started losing power after a period of use. Basically it will run fine then after some time, maybe a half hour or so, it will start to periodically lose power, almost to the point of cutting out. If I just sit there and turn the blades off after a moment it will regain power and run fine until it does it again. It seems to likely be a problem with the fuel delivery. I am going to get a new fuel filter as the next step. The thing that is so strange and interesting though is that it doesn't do it until after it has been running a bit. I found this thread the other day and this is exactly the same problem I am having. Unfortunately the thread has no final resolution. Any thoughts and help would be appreciated.
   / Kubota ZD28 Losing Power #2
You might want to double check but I believe that there is a hard to find filter that often gets missed near the frame other then the obvious one!
   / Kubota ZD28 Losing Power #3
I had to replace my 2 filters on my zd326 because it was doing what you described.
   / Kubota ZD28 Losing Power #4
I have to replace both filters and blow out the line every year. Always solves it. I also had to replace the electric fuel pump a couple years ago.
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
FAKE (A52472)
FAKE (A52472)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
