Buying Advice Kubota ZD1211 or Exmark Lazer Z X series
   / Kubota ZD1211 or Exmark Lazer Z X series #31
I honestly think some of us who mow at 3 to 5 mph are simply amazed at how fast zero turns can mow. But unless you are mowing the municipal ball fields, or have a big open lawn without many obstructions and plantings, not sure how anyone can maintain the top speeds posted for zero turns. Also means the motor is running flat out to make enough tip speed to mow the grass at that speed. Lots of discussions on whether to run air cooled mowers flat out, I don't..., but if you want to go fast, make a lot of noise, bounce around, and get the absolute max done, a ZT is the only way to go. All I can say is that some of us like to smell the roses a little bit more, I have serious back and neck problems and can't take the bouncing. So I'm happy to slow down, even with 5 acres of lawn to mow. Some of us drive Corvettes, some of us drive Buicks...
I think for many of us it's how fast can you mow comfortably. The improvements in suspension for lawn mowers has come a long way. I saw a link to some new Simplicity garden tractors that actually have leaf springs in front and rear. Leaf springs in a mower, remarkable. Well, Ferris has fully independent upper and lower control arms with shock absorbers.
We are getting little vehicles for our lawn.
   / Kubota ZD1211 or Exmark Lazer Z X series #32
Get a commercial quality ztr with suspension or at least a sus. seat. You will be happy. All the R and D is going toward zero turns. In 10 years tractor style mowers will be rare.
   / Kubota ZD1211 or Exmark Lazer Z X series #33
Unless they make a zero turn that's safer on hills I don't see tractor style mowers being rare, that's like saying there will be no economy car, every time I look, zero turns cost more $$
   / Kubota ZD1211 or Exmark Lazer Z X series #34
I went with a Kubota zd326 about 10 years ago, and do not regret my choice for a second. Just the fuel handling alone made a diesel worth the up front expense. The higher torque of the diesel, better fuel economy, and stability of a zero turn on hills make for a fast grass cutting experience.
   / Kubota ZD1211 or Exmark Lazer Z X series #35
I bought a large farm in the TN hill country and want a top quality mower that is durable and will last many years. I need something that can handle a hill, an occasional rock without braking and high grass if necessary. The Kubota is diesel & Exmark is gas. I was leaning toward the Kubota even though it is more than I'd like to spend but found that the Exmark is $2,500 less which is why I turn to you experts. Is the Kubota worth $2,500 more? And I'm open to another Zero turn option if there is something better than my top 2 choices.
So how many acres are you mowing a week? If you could provide pics of the land that would be awesome.
I would go with the Kubota ZD. But if you are on really hilly land I would suggest a Kubota F3860. However one is expensive and the other is crazy expensive! Haha!
Here's a couple videos about my ZD326. Theres no comparison on quality of Kubota ZD mowers and other brands. The ZD mowers are built like farm tractors with high quality transmission, engine, driveline, etc. I've seen ZD mowers with over 5,000 hours that have been run everyday that still fire right up and run well.
Zero Turn Mower Power House! Kubota ZD326 - YouTube
Zero Turn Diesel Power! Kubota ZD326 Mowing with POV - YouTube
   / Kubota ZD1211 or Exmark Lazer Z X series #36
Being a proud Kubota L45 owner when I need a new mower I went looking at the Kubota zero turn line. I wanted a long term mower but wasn't sure I wanted to pay the premium for the diesel engine given that my property is only a little over an acre. I went to the spring demo day a few years ago that my Kubota dealer was having and tried out the Kubota line and liked them. However, I have a number of steep slopes on my property and there was a large ditch in the test area and the Kubota was very difficult and did not feel safe trying to cut straight along the ditch slope.
My Kubota dealer had just become a Cub Cadet dealer and their representative suggested I try the new Z-Force zero turn with a steering wheel on the slope. I couldn't believe the difference - it was no problem at all to mow in a straight line along the slope and felt very safe. After four years I have had no issues with the machine and as others have pointed out the lawn is cut in less than half the time. I also burn about half the gasoline that I used to burn with my old lawn tractor mower with a comparably sized engine.
They may not measure up to the longevity of the commercial units with a diesel engine but the Cub Cadet zero turns with the steering wheel are excellent cutters on flat and sloped ground in my opinion.
   / Kubota ZD1211 or Exmark Lazer Z X series #37
That's great info! Yes the front wheels on the Cub are fixed and steer kinda like a lawn tractor. So all for wheels are holding directional stability. On a traditional zero turn the rear tires have to do all the work... propelling and steering. It's not for everyone!
   / Kubota ZD1211 or Exmark Lazer Z X series #38
I did not say that they would not exist, just you will have way fewer choices. It has already happened to garden tractors. You will only find a few. The SCUT has taken over.
   / Kubota ZD1211 or Exmark Lazer Z X series #39
I have had my eye on one of those steering wheel zero turn units, seems there not bad on hills
   / Kubota ZD1211 or Exmark Lazer Z X series #40
I researched ZTR's for quite a while but ended up going with a garden tractor (X590) because I like my machines to do more than one thing. With the garden tractor I can mow, tow a dump cart, chicken tractor, aerator, spreader, lawn sweeper, or run a snow blower if I want to.....ZTR's are faster but GT's are more versatile.
1299 (A58374)
1299 (A58374)
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
POLY BARREL & WELL TANK (A58374)
POLY BARREL & WELL...
3410 (A47477)
3410 (A47477)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
