Kubota ZD 1511-72 Fuel Economy
   / Kubota ZD 1511-72 Fuel Economy #1
sunnyside360
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
With a little over 25 hrs on the new Kubota ZD1511-72, I decided to check fuel use. The mower is averaging 0.893 gph. This compares to an average of 0.658 gph on the ZD331-72 which I traded for this unit. The ZD1511 uses 35% more diesel fuel but it is running at maximum rpms and mows my 6+ acres faster than the previous ZD331 which ran at approximately 75% throttle. It definitely takes less time to mow my yard with the ZD1511 but I don't believe it is 35% less time -- maybe 10 to 15% less time. So, the net is around 20 to 25% more fuel usage on the ZD1511-72. Additional fuel is likely due to the larger 4 cylinder engine besides supplying fuel for the regen process.
I'm posting this info since someone asked about fuel economy on the ZD1511 and I was curious myself. Nevertheless, I still much prefer the new ZD1511 with the air ride seat and improved stability/turning on steeper hills.
   / Kubota ZD 1511-72 Fuel Economy #2
Thanks for sharing.
I just purchased a ZD1211-60 and I am also curious as to the fuel usage.
Do you know, did your ZD have any regens? If not, then it seems likely your fuel usage will go up a little bit in future calculations.
Thanks for sharing.
There were two regens in the first 25 hours which were figured into the above fuel use -- one at 10.6 hrs and one at 21.8 hrs. I'm hoping the fuel economy improves with more hours on the machine.
   / Kubota ZD 1511-72 Fuel Economy #4
Seems that is generally the case. Although I've never payed attention close enough on my farm equipment, I do know that both of my diesel pickups got a little better economy until I hit about 20K miles on them. At that point they leveled off. Enjoy the new mower, I love mine.
   / Kubota ZD 1511-72 Fuel Economy #5
Sunny,
How did you measure the fuel consumption? I would like to measure my 1211-72 gal/hour but unsure how to get an accurate reading.
Thanks
Sunny,
Thanks
I store diesel fuel in a large tank with electric fuel pump and fuel gauge and keep a log book to record data for my equipment. At each fillup, I record date, amount of fuel, and equipment hour meter reading. The tank fuel meter indicates gallons to nearest tenth of a gallon.
   / Kubota ZD 1511-72 Fuel Economy #7
Beats my diesel tank with hand pump...thanks
   / Kubota ZD 1511-72 Fuel Economy #8
No regen is the main reason I went with the ZD1211. I would like the air ride seat. I may see if it is possible to swap and how much it would cost. Is it that much better than the suspension seat?
   / Kubota ZD 1511-72 Fuel Economy #9
I also bought a 1211 for the same reason. The air ride seat would be sweet, but the suspension setup on the factory seat is pretty darn good.
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
2005 Big Tex Trailer Trailer (A52377)
2005 Big Tex...
Two Post Car Lift (A50120)
Two Post Car Lift...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
