Kubota will not go forward after it runs a while
   / Kubota will not go forward after it runs a while #1
Bobbybrushhog
Crystal beach, texas
2008 L4240 kubota
Would anyone know why when running my kubota L4240 hydrostatic tractor for a while, when going in reverse, it kinda jumps forward before going into reverse, then, it will not go forward?
   / Kubota will not go forward after it runs a while #2
How many hours and did you do anything before this started to happen?
Thanks for responding murph. I have over 1800 hrs. This only happens when the tractor warms up. I mow a lot of rough stuff.
   / Kubota will not go forward after it runs a while #4
How long since hyd filter was changed? I presume the hyd oil is at the full mark.
   / Kubota will not go forward after it runs a while #5
Usually when a hydrostat warms up then looses charge pressure you have worn units, both pump and motor. But severly degraded fluid will cause the same problem but that usually means damage to the pump/motor. A plugged filter will cause problems when cold usually but fluid/filters is a good place to start along with charge pressure. Worn charge pump reliefs will cause this problem also. CJ
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
