Kubota will not go forward after it runs a while
   / Kubota will not go forward after it runs a while #1
Bobbybrushhog
Crystal beach, texas
2008 L4240 kubota
Would anyone know why when running my kubota L4240 hydrostatic tractor for a while, when going in reverse, it kinda jumps forward before going into reverse, then, it will not go forward?
   / Kubota will not go forward after it runs a while #2
How many hours and did you do anything before this started to happen?
Thanks for responding murph. I have over 1800 hrs. This only happens when the tractor warms up. I mow a lot of rough stuff.
   / Kubota will not go forward after it runs a while #4
How long since hyd filter was changed? I presume the hyd oil is at the full mark.
   / Kubota will not go forward after it runs a while #5
Usually when a hydrostat warms up then looses charge pressure you have worn units, both pump and motor. But severly degraded fluid will cause the same problem but that usually means damage to the pump/motor. A plugged filter will cause problems when cold usually but fluid/filters is a good place to start along with charge pressure. Worn charge pump reliefs will cause this problem also. CJ
2016 Dodge Charger SRT Hellcat Sedan (A55758)
2016 Dodge Charger...
2007 Ford Explorer SUV (A55758)
2007 Ford Explorer...
BUNDLE OF 58' X 10' EXPANDED METAL (A54756)
BUNDLE OF 58' X...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
