Kubota vs Massey advice
   / Kubota vs Massey advice
Once you own a Alo or Quicke loader, you’ll never want another brand. They are overbuilt, stout and easy to take care of.
Who makes the Massey FL series loaders?
   / Kubota vs Massey advice #82
Heavier is almost always better with tractors. It will help with stability (safety) and traction.
Most of us try to add weight by filling the rear tires (or some other options).
To a point you are correct, until the machine is just too big and heavy for the application. That was the point with my old Terex 640. It did road maintenance like a boss but was less desirable for small daily tasks around the ranch. I replaced it with a Kubota MX5200 and I should have done that sooner. Neighbor bought a similar sized Yanmar and it is too lightly bult for my tastes. He bent a loader arm pulling a post :oops:. I think Kubota in the 50hp size is a good compromise between weight and useability for a small ranch
   / Kubota vs Massey advice #83
Weight was one of the obstacles I faced when buying my last tractor, because I did not want to replace my pickup and/or trailer ... Trailer is 7K rated, weighs just over 2K, while the tongue takes some of the weight, I set a limit of only 5K for the tractor, BUT I wanted the most HP I could get to run as big of a mower as I could, pickup is rated for only 8900 Lb tow capacity, due to the silly 3.08 gearing ...
I was looking for no computer, or emissions stuff, which severely limited my selection ...
My cabbed Kubota is about 4300 Lbs, 52 HP, I really like my Massey Ferguson, and talked with my local dealer I bought it from a few times ... He just couldn't come up with anything that checked all my boxes ... But it's really only a big lawn mower for me.
   / Kubota vs Massey advice #84
Funny how some guys will defend Kubota’s advantage of “light weight”, while there’s like 3 active threads at any given time about filling tires with fluid and wheel weights on them.
   / Kubota vs Massey advice #85
Well, generally heavier is better when it comes to tractors, but ... For my one tractor I wanted as light as possible with as much PTO HP as possible for running a finish mower ... My other one I not only have filled tires, steel wheel weights, but came up with a way to add steel weight lifting plates to the BH mount when using the three point for added traction!
It's nice to have options! :)
   / Kubota vs Massey advice #86
I was concerned about hauling, too. Then I realized that the tractor I needed was going to be too heavy to pull without buying an expensive new truck.
2 years later, I haven't come close to needing to put my tractor on a trailer. If I get in a pinch, my neighbor has a big diesel flatbed work truck and trailer I could get a lift from. (Or there's always rentals)
   / Kubota vs Massey advice #87
Just to add to this, US model Kubota's only come with Kubota loaders. In Canada we have a choice of Kubota or ALO loaders from factory. (on the Utility models, M6 and up for sure)
Here too, in fact the Kubota dealers I approached for quotes, pushed the ALO (Quicke) loader over the Kubota genuine one for some reason.
ALO loaders are a much better tougher loader than Kubota's.
SR
Video from a Canadian Kubota dealer outlining the ALO built Kubota M32 loader and talking about the differences between the ALO and Kubota L series.
He says 10% higher price, when I bought last year the price difference between the M32 and L1154EA was way more than 10%.
   / Kubota vs Massey advice #88
I bought one of my ALO loaders back in the 90's, and hydraulic disconnect was an option then that I din't choose, no problem getting it at all.
I'm not sure why it wouldn't be available here in the states now.
SR
   / Kubota vs Massey advice #89
SR
Yes, ALO always had that option.
Might be a reference to factory hydraulic disconnect not being a Kubota orange loader thing. I don't think you can get the orange ALO loaders in US and they said the L loaders don't have it.
   / Kubota vs Massey advice #90
That is the idea. They are built light and you add weight to your liking.
Many people do not want a big heavy tractor on their fields for light tasks such as haying and pasture mowing.
2001 INTERNATIONAL 4700 BOX TRUCK (A59575)
2001 INTERNATIONAL...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
43055 (A55851)
43055 (A55851)
