Kubota vs Deere HST Comparison
   / Kubota vs Deere HST Comparison #1
hammer1995
Bronze Member
Louisiana
Kubota L3130 HST
I'm in the process of selling my L3130 and am considering either the Kubota 5740 (or 5240) or Deere 4720 (or 4320) as a replacement. The one thing I like about the Deere is the availability of the air seat and I would be willing to give up a little to get it.
I know the new HST Plus addresses some of the original HST issues. My question is how does the HST Plus compare to the Deere eHydro? I know the Deere has Stall Guard and such. What advantage(s), if any, would I be giving up by going with the Deere?
   / Kubota vs Deere HST Comparison #2
The hst+ has hi lo in each of the three ranges, it also has hydrostat responce so you can customize the way the machine operates to you. I dont think you will find these features on the JD ?
   / Kubota vs Deere HST Comparison #3
Kubota's adjustments also allows you to adjust the hydro for stalling. By running a 3130 most people would not need the stall gaurd other then for new operators. Otherwise you will find the six range far more benificial.
One prior owner we swapped a 4310 from stated it was nice as he didn't have to keep reseting the cruise speed when he needed to slow down for rough areas, he just dropped it a 1/2 range with his finger from the steering wheel.
With Kubota's system I think you will find that it is the best system on the market today in that class of tractors.
   / Kubota vs Deere HST Comparison #4
The Kubota's also have auto-throttle which has been a huge hit with many people. Its a bit hard to explain how all these things work together, but auto throttle, stall guard, and auto-HDS all work together to make about the best loader work transmission you could ask for. Deere has stall-guard, thats it.
Galvanized steel fence (A53424)
Galvanized steel...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
