Robert_in_NY
Super Member
- Joined
- Aug 1, 2001
- Messages
- 8,588
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I am weighing out the option of buying a simple, bare bones utility tractor to use in the vineyard for running a 5' rotary cutter and a mid mounted post pounder. 2wd is fine as I want it to be as affordable as possible. It doesn't need a fancy transmission either. The main restriction is width as I would prefer 64" outside width but can deal with 68" since fixing posts is mainly before the vines start growing again.
There are not very many Kubota tractors around here so I have never used one or been around them other then a couple RTV 1100's and a few sub-compacts.
So how well do the basic M series tractors work for you guys? Is there anything you feel Kubota should improve on them?
I have also considered the L3700 but its more compact then utility and while it will work for the two jobs I have in mind I don't want to limit myself and not be able to use it else where. The M would have more weight which would help during harvest if I needed to use it and the L would be completely useless during harvest as it would never be able to handle the weight properly.
But for curiousity, how well do you like the L3700? Isn't this the tractor that you guys keep talking about with the jerky 3pt lift?
And finally, since I am limited to browsing Kubota.com to learn about these tractors is there any other tractors I should look at? I am going to buy a M8540 narrow shortly for spraying and really don't want to buy a second narrow tractor as you pay more for the narrow tractor then a standard and if I can make a standard tractor work I will prefer to save that money for now.
