Kubota UDT or gear lube for front axle case
   / Kubota UDT or gear lube for front axle case #21
I use gear lube in the front axle also rather then UTF however the "viscosity" isn't the reason the additive package is.
Interesting chart here;
And a link to the article;
Gear Oil vs. Engine Oil: What's The Difference? - AMSOIL Blog
There are several charts and articles on this same subject.
Also most hydraulic/transmission fluids are a multi viscosity usually around a 10-30 a few are 15-40 and many of the synthectics are a 5-40.
1999 FORD F-150 TRUCK (A52708)
1999 FORD F-150...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
Michigan L90 (A55272)
