Kubota UDT and JD Hy-Gard: Interchangeable?
   / Kubota UDT and JD Hy-Gard: Interchangeable? #1
nh_bota
Bronze Member
Southern NH
Kubota B2620
I need to add fluid to my Kubota BX2350 front axle. The only conveniently located dealer is JD-only, where I can obviously get their Hy-Gard product. Does anyone know if these two products are interchangeable? The JD site says that the Hy-Gard oil meets the Kubota service ratings for UDT and SUDT.
   / Kubota UDT and JD Hy-Gard: Interchangeable? #2
I use JD hy-gard in my Kubota 3710 gst. My local kubota place said no problem even when under warranty. I use the JD fluid because I use similar tools with my jd 5300 and didn't want to mix different oils and I don't have to have 2 different kinds of buckets or oils sitting around. I use Mobil delvac engine oil in all diesel tractors.
   / Kubota UDT and JD Hy-Gard: Interchangeable? #3
By the way, are you sure the front axle uses UDT? I beleive my Kubota 3710 uses a heavier grade of of oil in the front axle. Yours may be different than mine.
Thanks for the info. Yes, my front axle uses UDT/SUDT, which was surprising to me too.
CAT JUMP BOX (A53843)
7021 (A50322)
7021 (A50322)
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
