Kubota Transmission/Hydraulic Oil
   / Kubota Transmission/Hydraulic Oil #1
dogbone0649
2007Kubota L3240 GST
Is there a better or cheaper substitute for Kubota hydraulic oil?
   / Kubota Transmission/Hydraulic Oil #2
You will save even more money by not changing oils and filters. Stick it to the man
   / Kubota Transmission/Hydraulic Oil #3
I drop in or call a lot of dealerships around the South as I travel and only a few are willing to price match the dealerships that are willing to sell the UDT2 at a lower rate. I needed a 5 gallon bucket last week, and had to pay what my local dealership wanted, which was one fifty five sixty one out the door.
In the bank statement, when I marked what that transaction was for, I simply noted "Liquid gold". I won't be putting my grapple back on the tractor until I have replaced the seals in the cylinders! A little leak goes a long way with the UDT2!
In answer to your question, I don't know of one, and with the shuttle shift, I am not willing to try others. Just the shuttle shift part by itself lists for almost four thousand dollars, with no labor included, so I just keep adding and changing the UDT2 as necessary!
David from jax
   / Kubota Transmission/Hydraulic Oil #4
I've been wanting to try Petro Canada Duratran synthetic as Petro Can is a quality oil and I get it at cost, but been too nervous to switch.
So I use the Duratran in my old tractors.
I'm almost scared to see how much the SUDT is now. I had a stock of it at home here so haven't had to buy any since the covid gouging began.
Even the shelf price of Petro Can was scary until I got my discount.
   / Kubota Transmission/Hydraulic Oil #5
Why dont you tell us about your machine? Kubota made a wide range of machines and some really dont need the kubota oil.
Kubota 3240 GST
   / Kubota Transmission/Hydraulic Oil #7
For the average owner,maybe 100 hours per year that means you change oils every 2-1/2 years:what are you really saving?
   / Kubota Transmission/Hydraulic Oil #9
Mobil 424 is a very high quality oil that meets or exceeds Kubuta udt specs. Unless you operate in a lot of sub zero weather it should be more than up to the job. I purchased a 55 gallon drum about 18 months ago for $725.00. A lot of dealers stock it. You can buy 5 gallon pails, do not know pricing on them.
   / Kubota Transmission/Hydraulic Oil #10
Other than what came in my M9000's, never used Kubota lubricants but I do use lubricants that exceed the Kubota specs. In fact the transmission oil I use is actually slightly more costly that Kubota SUDT.
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
UNUSED FUTURE 40" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 40"...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
