Kubota Tractor problems
/ Kubota Tractor problems #1
BASS813
Denham Springs
Kubota
I just purchased a 2008 Kubota L4400 from an individual. It only has about 130 hrs on it. It worked fine at the sellers house but when I got it home I have a few problems. The Range or Shuttle shift lever sticks in high; When I try to start the engine I hear a "click" and all the dash lights go off like the battery is dead; and I cannot figure out how to get the hood open. The Manual shows to twist the hood "mascot" and open the hood. When I twist the mascot the hood releases partly but will not raise more than a few inches. Any advice or suggestions will be appreciated.
/ Kubota Tractor problems #2
The hood mascot might be rusted in place. Just keep trying after spraying some solvent. The battery is up front. Check the connections and go from there.
/ Kubota Tractor problems #3
I forgot to add the possibility that the bar holding the open hood in place may be bent and preventing lifting the hood.
/ Kubota Tractor problems #4
The Range or Shuttle shift lever sticks in high.
WHEN THERE IS A LOAD ON THE TRANSMISSION IT CAN BE DIFFICULT TO SHIFT. GET THE TRACTOR INTO A CONDITION WHERE THERE IS ZERO PULLING, ZERO PUSHING TENSION, OPERATE THE CLUTCH AND IT SHOULD SHIFT.
THE TRANSMISSION LINKAGE IS UNDER THE TRACTOR. LINKAGE IS NOT ENCLOSED, ITS "OUT THERE." LINKAGE CAN BE BENT OR PACKED WITH LEAVES/TWIGS,DIRT. AFTER BLOCKING WHEELS, CRAWL UNDER, REMOVE DEBRIS AND LUBE LINKAGE.
When I try to start the engine I hear a "click" and all the dash lights go off like the battery is dead.
IT IS A GOOD SIGN YOU HAVE THE CLICK.
IT COULD BE DIRTY BATTERY CONTACTS, EASILY, AFTER FIVE YEARS. IT COULD BE LOOSE BATTERY TERMINAL(S). IT COULD BE A DEPLETED ORGINAL BATTERY AFTER FIVE YEARS, CHARGED UP JUST FOR THE SALE. DO YOU HAVE A BATTERY CHARGER? TRY CHARGING AFTER CLEANING AND BATTERY CONTACTS WITH A WIRE BRUSH AND MAKING SURE BATTERY CLAMPS ARE TIGHT.
THERE ARE SEVERAL SENSITIVE INTERLOCKS ON YOUR TRACTOR. ONE RELATES TO PTO, LOCATED UNDER SEAT.
ANOTHER IS LINKED TO HST FORWARD/REVERSE PEDAL. IF EITHER INTERLOCK IS OUT OF ADJUSTMENT THE SOLENOID WILL CLICK BUT TRACTOR WILL NOT START.
THIS IS NO DIFFERENT FROM A DRAWER STUCK CLOSED IN THE KITCHEN. SEE WHAT IS DRAGGING AND PUSH OBSTACLE OUT OF THE WAY.
Tractors are complicated and work under high stress, sometimes. You need to be able to figure out basic malfunctions as they occur. New tractors have problems in the beginning too.
Post again if these suggestions do not solve the problems. The T-B-N community is here to help.
Consider taking your tracktor to the Kubota dealer for fluid changes, engine oil and hydraulic fluid, and a general going over. I would not run on five year old lubricants; old fluids are not lubricating to spec now. Such service could be $500.
/ Kubota Tractor problems #5
"When I try to start the engine I hear a "click" and all the dash lights go off like the battery is dead" - I had a similar problem with my L5030. Look near the positive battery terminal for any disconnects or fuse blocks, if they have had any water or dirt in them you may need to clean them. (hopefully you can get the hood open or you will need x-ray vision :laughing:)
Thanks jrepp44,
I got the hood up and found the problem; a loose positive cable. This tractor was being used about an hour a month for grass cutting at the seller's place. I think I have all the issues solved now.
Thanks to all for the info.
PALLET OF WOODEN STAKES (A68842)
PALLET OF WOODEN...
18 FOOT WATER/FUEL TRAILER (A67714)
18 FOOT WATER/FUEL...
More info coming soon. (A64557)
More info coming...
2021 CHEVROLET TAHOE (A66091)
2021 CHEVROLET...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2014 Infiniti QX60 SUV (A66738)
2014 Infiniti QX60...
