Kubota Tie Rod Ends (L4200)
   / Kubota Tie Rod Ends (L4200) #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
At least one of the joints on the outer tie rod end of my L4200 is toasted and wobbles, and the boots on both inners are torn, so I might as well replace all of them.
Questions:
1) Can I just replace tie rod ends or end ball joints, or does the whole tie rod assembly have to go?
2) If just ball joints or ends, are there any common automotive (non-Kuota) parts that cross-reference?
Thanks - Jay
   / Kubota Tie Rod Ends (L4200) #2
Jay the folks I got my 4200 from had just replaced all tie rods. They said you have to by the whole link on each side. Fairly expensive they said. I would take off and see if parts store has a replacement with right size shank if so just cut and weld replacable ends on .....
</font><font color="blue" class="small">( Jay the folks I got my 4200 from had just replaced all tie rods. They said you have to by the whole link on each side. Fairly expensive they said. I would take off and see if parts store has a replacement with right size shank if so just cut and weld replacable ends on ..... )</font>
Apparently I didn't take a close look at the tie rods before I posted. I called the dealer, and got prices for the entire left assy, and the right with one end. I thought the guy was nuts. I then went outside and actually looked at the tie rods. As it turns out, the left is one piece with the ball joints cast right into the rod. The right only has one cast end and one removable end. Each rod is are ~$130, and the removable end is ~$50, so it's a little over $300 to replace the whole mess. I'll probably just bite the bullet and get the OEM stuff - it's not enough savings to deal with the PITA of fabricating custom ones. Of course, I'll probably wish I did when I toast the rod end /forums/images/graemlins/smile.gif.
Jay
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2017 JOHN DEERE CP690 LOT NUMBER 194 (A53084)
2017 JOHN DEERE...
New Wolverine Skid Steer Tiller Attachment (A53002)
New Wolverine Skid...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
