Kubota T1870 engine cutting out
   / Kubota T1870 engine cutting out #1
Philip Lee
Ottawa, Canada
Kubota T1870
My 2004 T1870 is having a stalling issue. The engine is occasionally cutting out and stalling. It happens quite predictably as follows:
- starts to happen after the engine warms up (maybe 10-15 minutes
- when I go over the edge of a hill and point nose down (it is fine nose up a hill)
- when I turn abruptly to the left although occasionally also to the right
At first, I thought it was the seat safety switch however that is not it. I discovered that as it is stalling, you can 'recover' it by pulling the choke momentarily. If it were electrical switch, the choke would not affect it.
- It appears to me that it is a fuel issue, not electrical (safety switches).
- I checked the fuel lines back to the tank and they appear to be secured as expected.
1) I am thinking to replace the filter (cheap & easy)
2) What after that? Is there something in the fuel pump or carb that would be affected by incline?
Feedback is most appreciated!
Phil
   / Kubota T1870 engine cutting out #2
the float in the carb would be most affected by incline, assuming the fuel tank has enough fuel in it to be picked up..
   / Kubota T1870 engine cutting out #3
agree. have a zero turn walk behind mower that will occasionally do just that, but quickly regains when the angle is changed. float related
hope you're using ethanol free fuel, & yes, wouldn't hurt to change inline fuel filter
   / Kubota T1870 engine cutting out #4
possibly the fuel level in the float bowl is low due to a restriction somewhere. if the engine uses more fuel than can be delivered to the float bowl, the level will go low, and be critical of angles.. check that the needle valve don't stick, and the float don't have holes, also!..
71066 (A49346)
71066 (A49346)
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
1991 International 4900 Box Truck (A51039)
1991 International...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
