Kubota steering trouble
   / Kubota steering trouble #1
j886
B 2410 HST with front end loader. Just had all filters and fluids changed and now steering is very hard. Only turns a very little unless you are moving foward or backward. I also noticed the power steering and loader take a while to work when you first start up. Read a few post here about possible leak on the non pressure side of hydro system. Just wondering if anyone else has had this problem.
jim
jim460@aol.com
   / Kubota steering trouble #2
welcome to TBN.
I know it sounds crazy...are you sure there is hydraulic fluid after the change :confused:
I did check fluid and it was full !!!!!! On dip stick. I did read a post that a L series tractor had a leak on the return hose causing a steering problem, not sure if anyone had this problem with 2410????
   / Kubota steering trouble #4
Check your covers on the filters and see if they are on right. It sounds like you might be getting air into the system. Do you have a lot of air or bubbles in the oil?
Covers on the filters ????? Not really mech inclined how do I tell if air or bubbles in oil ????
thanks jim
jim
   / Kubota steering trouble #6
If you had the fluids changed at the dealer, I'd give them a call and tell them to come get it, something they did is not right.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
Truck Wheel Fenders (A51692)
Truck Wheel...
2019 Chevrolet Equinox SUV (A51694)
2019 Chevrolet...
