Kubota steering trouble
   / Kubota steering trouble #1
j886
B 2410 HST with front end loader. Just had all filters and fluids changed and now steering is very hard. Only turns a very little unless you are moving foward or backward. I also noticed the power steering and loader take a while to work when you first start up. Read a few post here about possible leak on the non pressure side of hydro system. Just wondering if anyone else has had this problem.
jim
jim460@aol.com
   / Kubota steering trouble #2
welcome to TBN.
I know it sounds crazy...are you sure there is hydraulic fluid after the change :confused:
I did check fluid and it was full !!!!!! On dip stick. I did read a post that a L series tractor had a leak on the return hose causing a steering problem, not sure if anyone had this problem with 2410????
   / Kubota steering trouble #4
Check your covers on the filters and see if they are on right. It sounds like you might be getting air into the system. Do you have a lot of air or bubbles in the oil?
Covers on the filters ????? Not really mech inclined how do I tell if air or bubbles in oil ????
thanks jim
jim
   / Kubota steering trouble #6
If you had the fluids changed at the dealer, I'd give them a call and tell them to come get it, something they did is not right.
40ft Sea Container (A52384)
40ft Sea Container...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2013 CHEVROLET TAHOE (A53843)
2013 CHEVROLET...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
