Kubota steering question
   / Kubota steering question
Check the center seal in the steering cylinder.
Would this mean that our free spinning steering wheel moments should happen only when the front wheels were pointing straight ahead, or maybe at full turn might indicate an end seal?
Don't know if this may be part of same problem, but sometimes, when have extreme load on front end and trying to turn, there is a pop & jerk on the steering wheel, before it proceeds to act normal.
   / Kubota steering question #12
Probably feeling the roller bearings breaking out there cages and being ground up by the gear teeth in the hubs. :D (I'm just joking...)
1111-A (A54756)
1111-A (A54756)
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2016 FREIGHTLINER...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
