kubota starterswitch
/ kubota starterswitch #1
Farmer2013
masillon,ohio
kubota 2230,WCac
I tried to turn off the tractor and it would not turn off . I blocked a wheel and over loaded it. To get it off. Thank for any ideas .
/ kubota starterswitch #2
Could be the key switch but I would suspect the fuel stop solenoid. The solenoid is usually around the top of the engine. Turn your key on but do not start the motor. You should hear a click, this is the fuel solenoid opening to allow fuel to your engine. When you turn the key off you should hear another click (might be delayed a few seconds), this is the solenoid shutting off the fuel. Cutting off the fuel flow is the only (well cheapest and safest) way to shut a diesel down. I suspect a bad solenoid or corroded wiring.
BTW, Welcome to the forum!
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
New/Unused ATS 60 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 60...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
72in Blue Diamond Grapple Bucket (A65579)
72in Blue Diamond...
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
