Kubota squeaky AC compressor
   / Kubota squeaky AC compressor #1
Komrade
Western Morgan County, WV
Kubota L3430 HST
Initially thought it was belt and tightened it, but it didn't help.
Sounds like clutch is not catching.
Any pointers to fix and diagnose it myself much appreciated.
Does not squeak with AC off
   / Kubota squeaky AC compressor #2
Check the voltage to the clutch when it's turned on and supposedly operating. If it's less than 12 volts then try "jumping" battery power to the clutch and see if it still slips when running under load. Could be a bad clutch (even a bad compressor or system charge I guess) or could be it's just not getting full voltage.
   / Kubota squeaky AC compressor #3
They do wear out, that is the friction plate(s) get too thin and won't securely lock up. Some are adjustable, most aren't so replace it. Just don't buy it OEM, Get aftermarket, much cheaper and compressor clutches aren't rocket science.
2021 Caterpillar 304E2 Mini Excavator (A46683)
2021 Caterpillar...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A46684)
2007 Ford F-150...
County Line Spreader (A49251)
County Line...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2015 Chevrolet...
2014 Kia Optima Hybrid Sedan (A46684)
2014 Kia Optima...
Kivel Single Prong Bale Spear (A49251)
Kivel Single Prong...
