Kubota Sputtering when I turn off
   / Kubota Sputtering when I turn off #1
Volvovader
Bowling Green, OH
B7500
ok...This just occurred for the first time today. When I was done mowing, I turned the ignition key off and pulled the stop switch and my B7500 sputtered for about 5 to 10 seconds before completely shutting off. Thought it was a fluke, so restarted and it did again. I will see what it does tomorrow. It almost acted like the old spark knock you get with gasoline engines. The tank was almost empty, so I did fill it up with new diesel before today's mowing. Bad fuel?? Any thoughts?
   / Kubota Sputtering when I turn off #2
I take it your machine has a manual pull type shutdown.
Sounds to me like the shutdown cable or linkage needs lubed or adjusted and is not pulling the shutdown all the way off.
   / Kubota Sputtering when I turn off #3
That sounds like the fuel shutoff isn't closing completely.
Maybe a small piece of dirt got lodged in the shutoff valve or the shutoff cable needs some lubrication??
Yes, manual pull switch. Thanks for the suggestions. Much appreciated
AGT HPW3000-1 (A50123)
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
Scag Mower (A50324)
Scag Mower (A50324)
1995 GMC CHIPPER/BUCKET TRUCK (A53426)
1995 GMC...
