Kubota Snowblower broke
/ Kubota Snowblower broke #1
techman
Veteran Member
N.E. PA
BX22
I went out to clear the second half of our 20" snow, my 12 year old front mount Kubota blower broke. I usually go through a shear pin or two, but this was a quick "plink" and everything stopped. I lifter the blower and backed up to take a look and found the reduction chain laying on the ground. Picked it up and headed back to the shed. I spent the next hour+ taking the blower off and putting the loader/backhoe on the BX22 to dig out the driveway (8/10 of a mile). It took me a total of 9 hours clearing 10+ inches. With all of the snow on the ground already, had to pile it quite high.
Back to the failure. I lube the chain at the beginning of each season with a light lithium grease. A postmortem on the chain looks pretty much like the clip came off the master link which led to a jam, bent links and broken rollers. Sprockets were okay. My next surprise was that the PTO drive shaft fell apart. The long center shaft is welded to a U-joint on each end. The jam chain jam broke a weld between the shaft and the U-joint. The weld did look like it penetrated much, and the jam torque pulled a bit of the cast steel off the U-joint. It was only about 1/16" to 1/64" thick, which appears to be the amount of penetration. A buddy of mine was able to MIG the shaft back on, saving me $ 300. The chain is almost $ 60 from Kubota, but the manual luckily specs it as an ANSI #40 chain. I was able to get 10' of chain, 4 master links and a chain breaker from Amazon all for $ 30. Lots of spares. Hopefully I can get the parts and get everything back together before the next snow. Bucket works okay, but takes a LOT of time.
paul
/ Kubota Snowblower broke #2
paul
You might be happy the PTO shaft parted. Good design of a shaft/U-joint that will part if the implement jams is a way of saving the drive line in your tractor. That break might be the best you ever had$
Good luck on the snow.
/ Kubota Snowblower broke #3
You need to replace the shear bolts with the proper grade bolts. They should have sheared way before the pto shaft ripped apart. You are lucky (hopefully) you didn't tear up the trans.
Bill
/ Kubota Snowblower broke #5
Bill
Might not be shear bolts on the PTO shaft for a front blower though, would there? Some of the pictures I've seen make it look like it's not a universal PTO shaft with shear bolts on the joints. If not, this is a good example why they would be good to have.
/ Kubota Snowblower broke #6
techman--I would have to check my owners manual, but I lube the chain on my blower before each use not at the beginning of each season. Could have something to do with this failure....Regards, Mike
/ Kubota Snowblower broke #7
According to the sticker on my front blower (2781) you should lube every 4 hours. The shield is less than fun to get off to lube (think bottom bolt!) so I drilled out a fair sized hole by the chain so I can spray chain lube on it after I use it each time. I let it idle in gear and spray the links as they pass by the hole.
/ Kubota Snowblower broke #8
Yes every 4 hours with chain saw oil per the manual. I lube every use via the hole provided on the top of the chain cover with the chain moving. A typical use is 1-2 hours depending on the amount of snow and how many neighbor's driveways I do :laughing:
The shaft has no shear bolts. The blower shear bolts are after the chain, which is a speed reduction. My assumption is that the chain jammed the shaft in a jumble when it broke, breaking the shaft's weld.
paul
/ Kubota Snowblower broke #10
My blower ( not Kubota) has a shear bolt on the shaft going between the gear box and the sprocket.
Bill
/ Kubota Snowblower broke #11
When lubricating the chain you should also check the tension of the chain. A too loose or too tight chain may have been a factor in the failure. On my blower it's a hassle. I can set the adjustment bolt where I want it but then when I tighten the reduction box bolts it tends to slightly alter the tension and I need to start over. It's a bit of trial and error to get the proper chain deflection (1/4" for my blower, B2781A).
I'll check/change the gearbox oil once a season but the chain I maintain every 3-4 uses which for me is about 2 hours of blower use.
Just a few comments. At the start of each season I do check the tension and gearbox. I coat the chain in light grease and also apply oil to supplement the lube. I do not do a check on an hourly basis, but I do check and regrease and oil based on how much use it has had. Might be 3 times a season. In my follow-up research I did learn that a master link has 20% less torque rating compared to the matching chain. I'll never know exactly what happened, but I am sure that age and fatigue were factors.
paul
/ Kubota Snowblower broke #13
I also had the master link go once but now I keep spares on hand and am extra attentive to chain maintenance.
/ Kubota Snowblower broke #14
Yeah, the chain shield is really absurd. The lube hole is an excellent solution. You will save a lot of time, hassle, and cussing, if you don't have to remove the shield every-time you lube. This thread is also a good reminder to check your chain tension too.
2013 Ford F-550 Ambulance (A59230)
2013 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
17601CFL (A59228)
17601CFL (A59228)
2025 JMR 66in Hydraulic Single Cylinder Brush Grapple Skid Steer Attachment (A59228)
2025 JMR 66in...
2020 PETERBILT 579 TANDEM AXLE SLEEPER (A59905)
2020 PETERBILT 579...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
