Kubota shuts off intermitternly
/ Kubota shuts off intermitternly #1
little k
Marshall IL
L2800 & a 1970 4020 D
I posted a while back that my tractor would shut off then restart. I see that someone else is having more or less the same trouble. I changed several parts all to no avail.The last part i put in was a new key switch. Though it was fixed. Guess what. Still doing the same thing. I talked to a lawn mower shop they used to sell small tractors. He said with the clicking before it dies it could be a relay in back of the dash. he said there may one marked fuel. Have not checked yet. Also i saw some relays or brakers up by the battery. will check all of this out at some time. Hope this will help some one. By the way my tractor is a Kubota L2800.
/ Kubota shuts off intermitternly #2
Ah yes, that would be me having similar problems.
Still hunting the final solution... but have cleaned up a lot of things (maintenance wise) and learnt more about my rig along the way.
Fortunately, it's still an "annoying" fault.
/ Kubota shuts off intermitternly #3
Not sure if this is going to fix your issue but my tractor is doing the same thing, turns out it was my fuel control module. This is on a case 75a, yours may not have the same electrical components but it's somewhere to start.
Good luck.
AM
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
Quick Attach Backing Plate (A65579)
Quick Attach...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
