Kubota shuts off intermitternly
/ Kubota shuts off intermitternly #1
little k
Marshall IL
L2800 & a 1970 4020 D
I posted a while back that my tractor would shut off then restart. I see that someone else is having more or less the same trouble. I changed several parts all to no avail.The last part i put in was a new key switch. Though it was fixed. Guess what. Still doing the same thing. I talked to a lawn mower shop they used to sell small tractors. He said with the clicking before it dies it could be a relay in back of the dash. he said there may one marked fuel. Have not checked yet. Also i saw some relays or brakers up by the battery. will check all of this out at some time. Hope this will help some one. By the way my tractor is a Kubota L2800.
/ Kubota shuts off intermitternly #2
Ah yes, that would be me having similar problems.
Still hunting the final solution... but have cleaned up a lot of things (maintenance wise) and learnt more about my rig along the way.
Fortunately, it's still an "annoying" fault.
/ Kubota shuts off intermitternly #3
Not sure if this is going to fix your issue but my tractor is doing the same thing, turns out it was my fuel control module. This is on a case 75a, yours may not have the same electrical components but it's somewhere to start.
Good luck.
AM
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A65563)
2012 Mitsubishi...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2007 MACK CTP713N TRI/A DUMP TRUCK (A59914)
2007 MACK CTP713N...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
