Kubota rtv900
   / Kubota rtv900 #1
Wiggie
RTV 900 Kubota
Battery dash light stays on. When started the night will not go off. Battery voltage does not change. Is this a battery or alter tissue?
   / Kubota rtv900 #2
Have you measured the voltage with the engine running,with a voltmeter?
If your charging system is not functioning,the voltage will be battery voltage-about 12.5 volts DC.
A properly operating charging system will produce about 14 volts.
If you are looking at your voltmeter on the dash(if you have one),or in your hand when starting the engine,and you don't see the voltage increase to 14 volts or so,you have a bad alternator or something else wrong,requiring further testing.
Good Luck!
   / Kubota rtv900 #3
If the battery light stays on after starting the engine it usually indicates the alternator output does not exceed the battery voltage - your battery is not charging. This can be as simple as dirty battery terminals but it can also indicate worn brushes, a bad diode, a voltage regulator failure, or even a slipping fan belt. You do have a bit of testing to do.
   / Kubota rtv900
Good Luck!
Thank you , with engine running using hand volt meter only getting 12.6 so will pull the alternator
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
2015 Kubota MX4800 4WD Tractor with LA1065 Loader Backhoe (A53421)
2015 Kubota MX4800...
