Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #1
JDPN
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #2
Re: Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System
Why don't they offer that or any remote hydraulic on the RTV 1100?
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #3
its comming.
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #4
MessickFarmEqu said:
its comming.
Any idea of when? Will it become standard?
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #5
won't be standard. Heck we've never sold a utility valve kit. Its just a matter of time I'm sure. You do know what this is for right?
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #6
We had equipmet in the Army that was hyd powered and beleive me that pavement breaker did a slick job, the chain saw wasn't no slouch neither.
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #7
I looked at this as I am looking at buying a UTV sometime and thought this option would be great for in the orchard and vineyard. Then I priced out the attachments and that was the end of my thinking about it:(
I ended up buying a Husqvarna pole saw and hedge trimmer and they work great for our use and I am not tied to a hose and the pole saw was a lot cheaper. For the hand trimmers it would be easier for me to buy a pto powered air compressor and use that like we did when my neighbor owned the farm. Then the hose only has air in it instead of fluid so it is easier to drag up and down the rows.
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #8
I have a hydraulic tamper which takes about 5-6 gpm. It would be nice for fixing fence. Skid flow is a little fast at idle and tractor is about right at higher rpms. RTV should be similar to tractor. I am also consider a hydraulic pole chain saw for trimming trees.
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #9
If you get a hydraulic pole saw would you please post a review? I know it is cheaper to buy a gas powered top of the line pole saw then the hydraulic version. The gas powered units also are not limited to the length of the hose which is what turned me off about the hydraulic versions. Using them in bucket trucks make sense because the hose is short and you don't have to walk around any. I just couldn't see a good use for them off of the RTV to justify the price. The post pounder would be a good option though as would a few of the other hydraulic tools. I just wish the price of the tools were a little more reasonable as this could be a good thing.
   / Kubota RTV900 worksite and turf utility now standard with Hydraulic Power tool System #10
The price of hydraulic tools are a bit nuts. My plan was to use a hydraulic pole saw in a small man lift on my skid steer or CUT. I have walnut trees I was wanting to prune. The reach of the pole saw seemed like a good idea instead of the weight or noise of a chain saw.
JLG 1255 Telehandler (A52748)
JLG 1255...
Wood Fence Posts (A50121)
Wood Fence Posts...
2011 Ford F-150 Platinum 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A50322)
2017 Caterpillar...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
