Kubota RTV500
   / Kubota RTV500 #1
Michael Aos
Colorado Springs
Kubota BX2370-1 RTV500
Picked one up this afternoon.
   / Kubota RTV500 #2
Congratulations! One of Kubotas most handy and fun, working machines.
   / Kubota RTV500 #4
Let's hear an update on the 500 after a months use.
   / Kubota RTV500 #5
Four comments from experience:
1) Mine was sensitive to ethanol gasoline over one month old. Symptoms are like old vapor lock. I use only non-ethanol marine gas; problem gone. At least on other RTV500 owner has reported identical problem here.
2) Suspension is set pretty stiff from the factory. I adjusted mine from center position to lower position and it rides more comfortably. (five increments available.) Manual says you need a special spanner, which Kubota/USA does NOT sell. Adjustment made easily with a large "Channel Lock" plier.
3) After a year RTV500s sag to the left, driver's side. Stiffen left spring one notch to even up. Kubota cannot provide one spring rate for drivers 70 pounds to 315 pounds.
4) Great paired with a MUTS all-terrain, dumping trailer.
   / Kubota RTV500 #6
Ethanol gas has NO affect on my 500, no matter how long it sits...
The fuel injected motors I own, are the ONLY motors that I own, that don't seem to be affected by ethanol fuel, even when they sit for a time...
SR
   / Kubota RTV500
I think it had less than an hour on it when purchased new. Now up to around 8hrs. Most trips are only a couple minutes. Worked awesome to spray some weeds on Saturday. IMG_3863.JPG
   / Kubota RTV500 #8
In Florida we have year around high humidity and warm temperatures, distinct from your Upper Mid West conditions. I have been told that our ethanol never gets a "winter" blend, we get the same gas blend all year. It is possible this is more a regional SE USA problem. I do not know.
Perhaps others will share their RTV500 fuel experiences.
   / Kubota RTV500 #9
I run ethanol in my 400 never and issue. I also use mine more that most do and avg about 200 hrs a yr . and I avg 10 hrs per tank
   / Kubota RTV500 #10
Different engine from RTV500.
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
1275 (A50490)
1275 (A50490)
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
